12-28-2016 03:01 PM - edited 01-05-2022 01:27 AM
Hi does anybody know if the $40/month plan (90day plan) includes unlimited text and voice mails along with the 2G data, unlimited text and unlimited talk?
also, can this 6G total be used anyway i want within the 90 days or am i limited to 2G per month?
thanks for the help!
Chris
12-28-2016 03:32 PM
I see thank you
12-28-2016 03:16 PM
If you pick Unlimited Province-Wide talk and Unlimited Globat Text with 6GB on 90 days, you will have unlimited talk to your province only, you can text anywhere in the world and that 6GB you can use however you like throughout your 90 days. When you run out, you simply won't have access to any data. So you have an option to wait for renewal or buy an add-on that doesn't expire till you use all your data.
This post will help you understand how province-wide talk works: http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Province-wide-Canada-wide-and-Long-Dist...
12-28-2016 03:10 PM
Hi @yoochangsook,
The 90 day $40 plan includes unlimited call and text within your home province.
You will need to buy add-ons if you want to call a number outside of your province if you are with in your province or to make and recieve a call whenever you are outside your province.
As for the data, yes, you can use all your 6GB in 1 day if you wish. You will not be limited to 2GB per month.
Hope this helps.
