4 digit code
Donjfry
I am wondering how to reset my 4digit code ? I lost mine.  This is the code you have to enter when you call in by phone and are looking to see how much data you have left..
Donjfry
Thanks again. Cheers
GR
@Donjfry   could be 48 hours or so
Donjfry
Thank you.   I sent them a message. I guess it takes a while to get a answer?
GR
@Donjfry  to change that pin code you'll need to message the moderator_team and tell them you forgot it and want to change it.
The only way to reset your account PIN is to contact the moderators.  That can be done using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
