1GB and holiday data
pkaraa
I have 250mb plan but now I have holiday add on data and 1GB promotional data.
I know 250mb will renew every 30 days.
My question is how long 1 GB promotional will last?
untill I run out of it?
how long the holiday offer will last?
Cheers
2 REPLIES 2
notchman
Summary of add ons:
If you need U.S. Roaming, Long Distance or extra data added to your plan, choose one of the Add-Ons. Please note you’ll need a plan before you can add an Add-On, which will come into effect immediately after purchase.
U.S. Roaming Add-Ons expire after 10 days. Any unused data expires at the end of the U.S. Roaming Add-On.
U.S. Roaming Add-Ons are not available if you're on a grandfathered $19 plan.
U.S. Roaming MMS service (picture or video) requires both SMS and data service to be enabled and will consume data if used. If you choose SMS service only, MMS will not be enabled.
Add-Ons that are not U.S. Roaming related don’t have any expiry dates. Any remaining data or minutes in your Add-On will continue to roll over until they are used up.
kb_mv
Cheers
@pkaraa The data lasts forever or until you use it all, whichever comes first. If you run out of plan data the add on kicks in until your plan renews and then plan data starts again.
