$18 plan
anotherusernam1
I am on the older $18 a month plan I get 250 at 3G 100 minutes of outgoing calls unlimited incoming calls and texts.  If I switch to the new $18 plan what will I give up in the way of the rewards that I'm already getting on the older $18 plan?
2 REPLIES 2
Rewards specifically relate to the points that a customer receives for spending a certain amount on a plan, the points given for year anniversay, for points given for Community participation, and the points given for the number of referrals.  As you're going from one $18 plan to another $18 plan, none of these rewards that I've mentioned changes.   If you're getting other types of bonuses such as bonus data or discounts on your plan price, those aren't actually part of the rewards program.
slusagm
changing plan won't affect your current rewards. So, change it to the better $18 plan.
make sure you use Change on Renewal option to schedule the plan chnage
