09-08-2019 12:51 PM - edited 01-05-2022 08:50 AM
The $10 plan says 50 outgoing “International texts”. Are the incoming unlimited texts also “International “ because it doesn’t say so?
Service
09-08-2019 01:58 PM
09-08-2019 01:37 PM
Public Mobile accepts incoming international texts. A potential problem is if the international sender's carrier is able to send text messages to a Public Mobile number on the plan that international customer subscribed to.
09-08-2019 01:30 PM - edited 09-08-2019 01:33 PM
@Grahamk wrote:So is there a plan that let’s you text and receive outside of Canada?
Only roaming in the US.
Unofficially, while in the states, you can receive texts and calls. You just can't call or send out without a roaming add-on.
09-08-2019 01:25 PM
09-08-2019 01:17 PM
yes, you can receive the text messages from anywhere.
09-08-2019 12:57 PM
09-08-2019 12:54 PM
@Grahamk wrote:The $10 plan says 50 outgoing “International texts”. Are the incoming unlimited texts also “International “ because it doesn’t say so?
People can text you from anywhere but you'll only receive them while you are in Canada
09-08-2019 12:53 PM
Hello,
Normally the incoming texts/calls can originate from anywhere. Phone companies only control outgoing text/calls.
