1-8xx numbers
Techy76
Good morning.
Does calling 1-8xx toll free numbers use up your minutes on limited talk plans?
I'm looking to switch over from Virgin and would like to know how this compares.
Thank you!
10 REPLIES 10
geopublic
@Techy76 wrote:
Good morning.
Thank you!
@Techy76  Just out of curiosity does calling  toll free numbers use up minutes on a limited call plan with Virgin?
@will13am wrote:
@Anonymous wrote:
 @Steve_B
I'm on the $10 plan. I'm just relaying my actual experience...not a brothers friends nephew. The $15 plan is probably the same. I suppose I could test that some time.
Must be another system bug but this one is in favor of the customer.  My preference is to rely on the official information even if wrong.  Who knows, one day it might be correct even if Public Mobile is known to foot drag on these kinds of things.
As we know, there are several "system bug"s around here. So sure yeah if there's an official written statement then the benefit may disappear at some unknown time.
@Anonymous wrote:
 @Steve_B
will13am
@Techy76, take a look at this knowledge base article.  A call to a toll free number will count against the usage allotment.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Plans-amp-Add-Ons/ta-p/250167
Steve_B
Other things to take into account when looking to switch providers, is the coverage that they all provide. Sometimes going with the least expensive one will also give the least amount of coverage, making things very frustrating from a usage standpoint. Depending on where you are located, that's something to think about as well. Your budget is obviously your first consideration though, and since you can port numbers now and you don't need to be on a contract with PM, if after 30 days you're not liking it, you can go to another provider.
missorange
@Anonymous not counting mins when you call 1-8xx? good to know.
 @Steve_B
Steve_B
The reason I quote TELUS is because Public Mobile is owned by TELUS. When I used to have 500 mins per month and called 1800 numbers, I noticed that mins were deducted from my monthly plan.
Steve_B
According to a TELUS forum, 1-800 numbers are counted towards your plan. So if you call one, it will take minutes off of your plan. You wouldn't need to pay long distance at least, but it will still use your minutes.
@Techy76 wrote:
Good morning.
Thank you!
It has been my experience that minutes are not counted for *most* of the toll free numbers. I seem to think the more recent ones might but I haven't tested one in a while.
