GPS Time Reset Issue Impacting Location Accuracy on Select Phones
04-05-2019 02:03 PM
Public Mobile has identified a small number of select devices that, as of April 6th, 2019, will no longer provide accurate location functionality. These devices may, however, obtain some location functionality through wireless tower triangulation so Emergency Services may continue to get locations for these customers.
Public Mobile will communicate to all impacted customers to make them aware of this issue and encourage them to download the applicable software patch to their devices to resolve this issue.
Public Mobile has worked with manufacturers to roll out fixes to affected devices. If your device is listed below, please update your devices to the latest software.
- Alcatel A50 (5085O)
- Alcatel 1 (5033O)
- Alcatel Lume (A466T)
- Alcatel Pixi 3(4) (A460T)
- Alcatel Pixi 3(4.5) (5017O)
Some devices, however, will not receive software patches due to their age. If your device is listed below, please be aware of this issue and exercise caution if you find yourself in a 911 situation. Alternatively, you can purchase a new device.
- Alcatel A392A / A392CC
- Alcatel Idol X+ (6043A)
- RIM BlackBerry Curve (9320)
- RIM BlackBerry Curve 3G (9300)
- RIM BlackBerry Torch (9800)
- RIM BlackBerry Bold (9700)
- RIM BlackBerry Curve (9360)
- RIM BlackBerry Bold (9780)
- RIM BlackBerry Bold (9790)
- HUAWEI Ascend Y330
- HTC Desire 320a (0PF1100)
- Motorola Charm (MB502)
- Motorola Defy (MB525)
- Motorola Key (EX225)
- Motorola Milestone (A853)
- Nokia 3710
- Nokia E71
- Nokia E72
- Sonim XP5560
- Sonim XP5560IS
-Public Mobile Community Team
04-09-2019 12:25 AM
@Inspired14u wrote:So my Dad has an older LG-A341 and ever since the GPS reset he has had no service. Is it possible this was caused by the GPS reset? I have removed sim, powered off/on, reset the device but can't get anything. Any suggestions?
It's a coincidence. You don't need GPS for phone calls, texts, or data.
04-09-2019 12:03 AM
Does it say active on the account?
If limited minutes, are they all used?
Does the phone have GPS aka location services?
I would highly doubt improper functioning of GPS would affect all the other phone services.
04-08-2019 11:58 PM
@Inspired14u Did you try putting the sim in another phone to see if its a problem with the service or the phone?
04-08-2019 11:57 PM
04-08-2019 04:46 PM - edited 04-08-2019 04:54 PM
@Anonymous wrote:So my idea of seeing if the GPS in ones phone or other devices shows a wrong date is a valid way of testing? Assuming the program one uses that displays a date is actually getting it from the GPS.
Totally. Many (older) devices went from Apr 6, 2019 23:59:59 GMT --> Aug 22, 1999 00:00:00 GMT, so it was a quick/easy way to check. Many devices needed to be power-cycled for this effect to be observed, but that's definitely a valid way to check. Many devices could use multiple sources for time (e.g. GPS, cell, or NTP servers), so it's important to be aware of which source is being used for tests.
@Anonymous wrote:if one doesn't have their GPS on then will this emergency locating thing work at all anyway? I know some triangulation can be done using the cell towers but if the phone doesn't have the GPS radios on then how would it be found other than the general vicinity?
Yes, it should work, but I haven't been on top of E911 specs in the last 20 years (I worked at a company that did this stuff when E911 was in its infancy). I don't think most truly use triangulation (a term over-used in dramatic TV series and movies), since determining angle of signal arriving at a cell tower with any degree of acuracy is extremely difficult if not near impossible. Location based on signal latency is more likely achieved by trilateration, and more specifically hyperbolic trilateration through time-difference of arrival calculations. I won't go through all the details (I'm sure Google has answers), but suffice it to say that trigonometry and quadratics from high school math class come heavily into play!
04-08-2019 04:32 PM
So my idea of seeing if the GPS in ones phone or other devices shows a wrong date is a valid way of testing? Assuming the program one uses that displays a date is actually getting it from the GPS. And then there's Glonass...:)
This would be more of a general haven't looked kind of question...if one doesn't have their GPS on then will this emergency locating thing work at all anyway? I know some triangulation can be done using the cell towers but if the phone doesn't have the GPS radios on then how would it be found other than the general vicinity?
04-08-2019 04:23 PM - edited 04-08-2019 05:01 PM
@Anonymous wrote:
@Jessica_T wrote:Will this mess up google maps or only emergency services?
Seems to be a thing. A little searching and I find GPS Week Rollover. Happens every 1k weeks due to a limitation in the datastream from the satellites. It last happened in Aug 1999.
Perhaps a way to test it is to use a GPS program and if it comes up with a date of about 20 years ago then the GPS in the device is not capable of dealing with the effect.
Yep... a thing!
I spent much of my weekend (Saturday evening, anyway) testing/validating things were working for the company that employs me, since GPS is everything to us (telematics). It's sort of the Y2K of GPS.
Old firmware could affect ability to acquire location for certain devices, but more likely to impact date/time functionality. A fleet of Chinese Boeing 787s were grounded due to this glitch... they should get ontop of their firmware upgrades! 😜 Fortunately no planes fell out of the air from this bug...
The more cataclysmic end-of-days event for us to be worrying about is January 19, 2038 at 03:14:07 GMT. This is the roll-over of Unix Epoch time, which is what pretty much all computers are based on. Now that will be a bigger deal... (mind you, as long as people use an unsigned int32 or bigger, it should all be good... this only affects programs that used signed int32 variables).
04-08-2019 04:17 PM
@computergeek541 wrote:
There have been some talk about networks blocking duplicate IMEIs or IMEI numbers that are made up of all zeros, but other than that, it really doesn't matter.
Agreed. Although right now IMEIs consisting of all zeros are not exempted from Canadian networks AFAIK. You'd be surprised at how many phones show up with all zeros if you could access a carrier's database... back in the day, one way to "unlock" a phone was to do a factory reset, which also cleared out the IMEI (unbenknownst to many users, following instructions found online).
@computergeek541 wrote:The IMEI of your device is automatically transmitted from the device to the network as soon as it conects. There is no choice on this matter, nor do you have to do anything for Public Mobile/Telus to know about it. It is also during this process that Public Mobile will check to see if the IMEI is blacklisted from use.
I remember back when I was with Koodo, your current IMEI would show up in the self-serve portal under your account. When unlocking a phone (back then it was pay per unlock), I'd simply insert my Koodo SIM card into the phone I wanted to unlock (often I was unlocking for a friend or family member), make sure the IMEI had refreshed on the portal, and then call up Koodo and ask for an unlock. They'd ask... "is this for your current phone with IMEI XYZ?" to which I'd say "Yup!". Made it easiest for everybody (they knew I had the phone in my possession, and they could copy/paste the IMEI from their screen).
04-08-2019 01:20 PM - edited 04-08-2019 01:21 PM
@dna2016 wrote:@computergeek541, how does a company know the IMEI when you put your SIM in a different phone? I don't see how that is possible, but please educate me on this because that is definitely new to me.
@Munday definitely nothing to worry about, if anything maybe contact a MOD to see if there's a way to update your IMEI so you won't get any messages that apply to your old device. I checked "My Account" and I don't see any options to change the IMEI.
There's really no reason to update the information on the account. The IMEI that Public Mobile has on record would only come into play if porting the number out. Howver, you'd be much better off using the Public Mobile account number. The IMEI on record could be wrong, invalid, of an old device, or just nonsense such a much of ones and it would make no difference to your service. There have been some talk about networks blocking duplicate IMEIs or IMEI numbers that are made up of all zeros, but other than that, it really doesn't matter.
04-08-2019 12:28 PM
WOOWWWWWWW!!!! These are some pretty old devices. Didn't think I would ever hear about the Blackberry Curve 9300 series and Nokia E71. When I use to work in the industry over 10 years ago those were some of the phones I was selling. I'm surprised these phones have even lasted that long, especially the Blackberry's. People if you have one of these phones I highly recommend it's time to upgrade. If you made it last this long then definitely my hats off to you......but it's time to move on, shed a tear for the memories, lol.
04-08-2019 12:22 PM
@Munday when you first set up your account with PM you would have entered your IMEI, and that's why you received the text. It's going off of your prior device, not your current. I'm not sure about how they would know your IMEI as soon as you connect to the network (regarding when you switched to your new phone) @computergeek541, how does a company know the IMEI when you put your SIM in a different phone? I don't see how that is possible, but please educate me on this because that is definitely new to me.
04-08-2019 10:18 AM
But my flip phone still works right? Its not on the list....
04-07-2019 11:02 PM
As always...I'm no expert 🙂
04-07-2019 09:54 PM - edited 04-07-2019 09:59 PM
My understanding is that it's the accuracy of locations for anything that uses the GPS, including mapping software, although only some devices will be affected, especially older ones.
Here's some information from one of the standalone GPS device manufactuers, although Garmin is saying position accuracy isn't a problem with their devices: https://support.garmin.com/ms-MY/?faq=zWQY6Z2kFiAuY9kDnDBgZ6\
and from another company: https://www.orolia.com/resources/blog/lisa-perdue/2018/gps-2019-week-rollover-what-you-need-know
04-07-2019 09:39 PM
04-07-2019 03:19 PM
I agree with what would seem to be a properly technical way to do it. But it seems that people struggle with porting from Speakout and apparently, from what I understand, this is due to needing to use the IMEI on file and not necessarily the current device.
But I'm just going on what I think I've gathered from this place...not personal experience.
I'm open to it all being wrong. You don't need to be quite so harsh.
Do you have actual personal experience porting from Speakout after changing devices while there?
04-07-2019 03:10 PM - edited 04-07-2019 03:12 PM
@Anonymous
This is false
The second your cell phone registers on the Speakout network (place a call or send a txt) you now need to provide that new IMEI in order to port the number
That is why many people fail port with Speakout
They try using older IMEI after upgrade
(Which is backwards from many networks, eg Bell/Solo/Virgin who always has original IMEI hardcoded on account of device you purchased/upgraded. They can SEE new IMEI but require OLD IMEI to port)
No idea if Telus brands follow Rogers but I strongly suspect they would be more like Bell since they copy them in most things
@Anonymous wrote:
@computergeek541 wrote:Public Mobile knows the model of your phone by IMEI. They know it as soon as you connect to the network, and also know any time you switch to a different device.
How does Speakout do it then? Since you have to provide an IMEI from the account that can apparently be different from the phone itself?
And then...isn't it curious that the OP got the text but the phone he has now isn't on the list.
04-06-2019 12:17 AM
@Munday wrote:I got a text from PM that my phone is one of the models affected by this problem. How does PM know what model phone I have? I now have a Motorola G4 Play, but did have a Blackberry Curve 9360 when I first signed up with PM last year. Does the IMEI come into play here?
Ok, Thanks. Since my Motorola G4 Play isn’t on the list Moderator Brooke wrote, do you think the PM text I received is going off the IMEI from my original Blackberry Curve?
If you look at the list of affected devices, I don't see the Moto G Play as having anything in common with the others, and it has a fairly recent Qualcomm Snapdragon chipset when compared to everything mentioned in the affected device list. I'm almost certain that your Moto G4 Play is fine. It's kind of like when there's a car recall and the manufactuers send recall notices to everyone registered to have purchased a model, even though they know that many of the vehicles are no longer in use, or have been sold/traded-in/upgraded.
Good explanation. Thanks Folks for your time.
04-06-2019 12:13 AM
04-06-2019 12:10 AM
I'm looking at the list of some of the affected devices, and some of those are 10+ years old. I know that in the case of the Nokia E71, those generations of Symbian phones had next to a useless GPS chipset anyways, often taking minutes to get a GPS lock even if you were under a clear sky. I do wonder how accurate cell phone tower triangulation is, but it clearly wouldn't be as accurate as the device's internal GPS.
Who knows what Speakout is doing. They could be using an IMEI that is manually typed in for all we know. It could be the first IMEI to connect to the network, or there could just be a long delay. All I can tell you is that when the phone connects to the network, the carrier knows the IMEI. Whether Rogers is sharing that information with Speakout is a different story. This is the very reason that IMEI should be avoided for number porting from most carriers, although I realize that Speakout requires it.
04-05-2019 11:59 PM
04-05-2019 11:59 PM
04-05-2019 11:54 PM - edited 04-05-2019 11:58 PM
04-05-2019 11:43 PM
