02-20-2024 10:30 AM - last edited on 02-20-2024 04:41 PM by computergeek541
02-20-2024 11:10 AM
Hotspot depends on your phone. PM only provides access to internet (through data) and does not manage your hotspot.
Did hotspot Ever worked through your current phone?
02-20-2024 10:50 AM
iphone or Android?
you can first try Reset All Networks, or Reset Network Settings first
If isuse persists, try :
on Iphone:
Check APN, go Settings -> Cellular -> Cellular Data Network -> PERSONAL HOTSPOT / APN -> sp.mb.com , and Leave Username and Password blank.
On Android, check APN settings, especially with APN Type:
APN Type: default,supl,mms,dun
or default,supl,mms,DUN
(try both as it is case sensitive)
02-20-2024 10:35 AM
Is everything else working properly? Ie. data Has hotspot worked before?
Here is some additional information:
https://www.publicmobile.ca/en/ab/get-help/articles/mobile-hotspot
A few basic troubleshooting advice: reboot phone. Network reset of phone (note - will erase any saved wifi passwords).
