4 weeks ago - last edited 4 weeks ago by computergeek541
hi all,
i have a oneplus Nord30 5g. I have had no luck in updating my apn setting in order to send photo texts to non-android users (what comes up as a rcs message). I've tried adding these settings WITHOUT deleting the original ones. Do I need to delete my original settings? Any other suggestions? the settings I changed to, below
Thanks.
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
4 weeks ago
Nah. With a great community like this, the solutions come fairly quickly.
4 weeks ago
Putting it all in caps worked immediately. Thank you very much!
4 weeks ago
4 weeks ago
@amyrie For some reason OnePlus phones seem to have more difficulty with this APN change, a couple of people have suggested that putting the SP.MB.COM line in all caps helps.
4 weeks ago
Best I can offer is the article below @amyrie :
