2 weeks ago
2 weeks ago
We have the same problem. There is an error on the website. Contact support.
2 weeks ago
It worked for me. I have a suspicion that to many failed attempts is causing credit card lock out.
2 weeks ago
HI @will13am
does this work? I see another replied saying it didn't work 😞
what is the issue, why it so hard to update card info ?
2 weeks ago
HI @Bertie7 did you try what suggested above?
also, it is not a good choice to use a phone number for user name, you might want to ask support agent to change it for you
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 weeks ago
i cannot update credit info
2 weeks ago
@Charley2 , used the app making sure that location permission is granted and that app cache is deleted before accessing the account.
2 weeks ago
hi @Charley2
wait an hour and try again using both browser and app
if you use browser, use Incognito/private/secret mode.
if you still cannot update card info, get a voucher from Shoppers drug mart and use *611 to load the voucher. Or get the voucher online from recharge.com
