06-11-2020 05:32 PM
How do I set up outgoing email? Incoming is good (I think, but may be only coming in thru wifi) but outgoing email gets fail message: "smpt dot telus dot net" not responding. Any ideas? Thanks!!
06-13-2020 06:58 PM
@BB2 you're welcome 👍
06-13-2020 01:06 PM
Thank you so much !!!!! 🙂
06-13-2020 01:05 PM
Thanks so much, that worked!!!! 🙂
06-11-2020 05:53 PM
@BB2 Can you try using port 1025 as your outgoing SMTP server port?
06-11-2020 05:53 PM
Two questions:
are you using the iPhone or an Android device?
Are you using the native email application (mail in iOS and email for Android) or using a third party (Gmail or Yahoo! Mail app)?
-> In each case, using a third party will be most useful, Gmail app in particular, is compatible with many email servers and it should be easy to use and it’ll solve incoming/outgoing servers automatically.
06-11-2020 05:52 PM
Change telus to your email provider in outgoing server settings
https://help.dreamhost.com/hc/en-us/articles/216662028-How-to-configure-email-on-an-Android-phone
06-11-2020 05:51 PM
@BB2 wrote:How do I set up outgoing email? Incoming is good (I think, but may be only coming in thru wifi) but outgoing email gets fail message: "smpt dot telus dot net" not responding. Any ideas? Thanks!!
Are you otherwise able to browse the internet on cell data? Send/receive MMS picture messages?
Are you a recent customer here? Has it ever worked?
Some email services don't like people using separate smtp servers. iirc it's called relaying. They don't like doing that on behalf of other services. But some are fine with it.
So you might need to set up the smtp server of the email provider you are using.
06-11-2020 05:47 PM
@BB2 Who is your email provider?
