05-03-2016 06:41 PM - edited 01-04-2022 02:39 PM
My # was unlisted and private with my last carrier. Can I request that it be unlisted with Public Mobile?
Payment
08-24-2017 11:36 AM
@CEMMEC first of all if you are being stalked, I'd strongly suggest you contact your local non-emergency police department and start a file right away.
As for getting unlisted, I'm not really sure, but I'd suggest you send the moderator team a private message using this link, and make the same enquiry there.
08-24-2017 07:43 AM
Hi,
RE: Unlisted.
How do I remove myself from the non public directory ? I need to also be unlisted to those companies that reverse lookup the number from your directory. This is important as I have a stalker.
thanks.
05-04-2016 10:17 AM
You're welcome, @Kozak. Your phone should have a call menu that includes a setting that will allow you to turn off your outgoing caller ID for all calls.
05-04-2016 09:54 AM
yes, thankyou for clarifying what I need.
05-03-2016 07:42 PM
@Kozak Cellphone numbers are not published publicly in a phone book or whatever.
Are you looking to have your outgoing caller ID blocked?
05-03-2016 07:03 PM
Good question! I am just subscribing to see if this can be done.
JL.
