security question
marilyn_parlee
forgot security questions
Daps
@marilyn_parlee  since you can't logon your account, you'll likely have trouble submitting a ticket. In this case, you should send a private message to moderators directly here
Check your inbox (message envelope at top right corner) to see their reply.
gpixel
@marilyn_parlee when using SIMon type "locked out of self serve"
(use the chat bubble options, then click "submit a ticket, click me" option)
make sure to check your inbox(top right corner envelope icon) periodically, for a response
kb_mv
You will have to contact a moderator. Be prepared to prove that the account is yours.
You can contact the mods one of 2 ways. Click the question mark bottom right of the browser as shown in the picture and open a ticket through the automated ticketing system;
or you can contact them through direct messaging at the following link (note this way may take longer for a response);
In either case you should receive a reply within 48 hours though typically they are much faster. Watch the envelope icon top right for a reply.
NDesai
@marilyn_parlee you will need to contact the moderator team via one of the following two ways:
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
