10-02-2018 02:39 PM - edited 01-05-2022 02:00 AM
I tried to connect to my account, but got this... If you block access with a CAPTCHA can you at least use one that works...
10-04-2018 01:31 PM
A few things you can try
1- clear the cache and the cookies of your current browser
2- try a new browser
10-02-2018 04:17 PM
Thanks, I'll try that, but for now I need to wait one hour before retry.
10-02-2018 03:48 PM
@cappaj wrote:
@cappaj wrote:I don't see that on the English version of the site - any chance that switching your language might get rid of the recaptcha?
I switched to the French version and still don't see the recaptcha, so maybe language has nothing to do with it.
What if you try in an incognito tab in Chrome? Maybe that'll get rid of it for you...
This is a good point @cappaj. Sometimes the recaptcha security prompt only comes up when there is a failed attempt at logging in, or other possible security breaches. Have you tried multiple browsers?
10-02-2018 03:45 PM
Oh dear, that is obnoxious. I wonder if something else broke with they fixed the password reset, and possibly only affecting the French-language site.
10-02-2018 03:41 PM
10-02-2018 03:21 PM
@cappaj, that's what I was looking at also - not on the English sign-in.
10-02-2018 03:10 PM
10-02-2018 03:02 PM
Password reset doesn't work either, I've sent a private message and I'm waiting for the reply.
10-02-2018 03:00 PM
unfortunately yes...
10-02-2018 02:53 PM
I too haven't seen a captcha prompt for Public Mobile. This can't be from Public unless they're trying something new.
Please no...
10-02-2018 02:47 PM - edited 10-02-2018 02:47 PM
@dcright I've never seen a captcha on Public Mobile sites. I think you should try to reset your password and then try logging in.
