plan
Whanjo
Hi.
1. I used have refer a friend reward  from my wife no. And my wife is still using same phone ,but reward is gone.
2. I already paid 90 days payment. If I change to 30days other plan  before finishing bill cycle, can I have  credit for diference?
 Even if i change 30days plan, can i keep current reward ?
 ( if i am 18mth user of pm, when i change plan it will be 0mth or 19mth for next month )
1 REPLY 1
matbasm
Hi @Whanjo,
@Whanjo wrote:
Hi.
1  If both accounts remained active, you should be receiving the referral reward.  You should contact the moderators about this
2  If you change the plan in the middle of a cycle, there is no credit for the unused portion.  However, you can make the change, and tell the system to only change the plan at the end of the current cycle.
3  If you change your plan, you are still on mth 18/19 (as far as loyalty rewards are concerned).
Click here to send the moderator team a private message.
Information regarding the moderators team can be found by following this link.
