need to switch to data plan
margkulokas
********** Marg Kulokas
my plan has to be changed to minimum data plan.
selfserve not working due to activation error in system.
Saray_O
Hi @margkulokas
I see that you were able to change your plan and that your Self Serve account is active 🙂
Let me know if you need anything else!
*Please do not post private info such as: phone number, account number, pin etc.. This is a public forum.
jimmyche
Please do not post your personal information on the community forum.
Right where you post is, click option on the right to edit your post.
Instead, you should get a hold of PM and provide your personal information thru the below methods:
Webpage> Get help> contact us
and/or
Private message mod from here
I would recommend you to do both. Please take note that at the moment, there's probably going to be a week long wait for fixing this issue. You can also try message public mobile through facebook.I had better luck with faster response there.
Refer to this link regarding how to message mod
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
UDP7
Have you private messaged a mod?
