01-17-2020 08:40 PM - edited 01-05-2022 09:04 AM
Hello! Can I choose a "public mobile" phone number that I like? How and where to do it?
01-18-2020 11:16 PM
@tweakthis wrote:"- if you want to port a number from another provider it must be from an exchange that Telus serves and both accounts must be active at the time of porting"
I was with Virgin Mobile and was able to port over my number.
Yes?
Your statement confirms that both your Virgin account and your Public Mobile accounts were active at the time of porting.
And that your Virgin Mobile number is from an area/city/town that Telus also offers numbers at.
Examples:
- it's highly unlikely that you will be able to port a 250-288-xxxx Telus landline number to Bell or Rogers, because the later two don't asign any numbers in Holberg BC. (It might also not be possible to port a Holberg number to Public Mobile since PM doesn't list it as an available exchange in their local calling area selector?)
- If you have a 250-284-xxxx or 250-209-xxxx number you should be able to switch to a provider in the Bell group because they offer numbers in Port Alice BC (250-904-xxxxx). However, Rogers does not.
- All three providers offer numbers in Port Hardy BC (250-230-xxxx, 250-902-xxxx and 250-949-xxxx are Telus numbers, 250-671-xxxx Bell, 250-527-xxxx Rogers) so you should be able to port, say, your Port Hardy FIDO number to Public Mobile.
All three communities are on northern Vancouver Island:
Phone number information comes from here: http://www.cnac.ca/co_codes/co_code_status.htm
01-18-2020 12:33 PM
01-17-2020 11:35 PM
@CannonFodder wrote:
@wetcoaster wrote:Just a reminder that:
- in self serve, the 4 digit search function is only available at the time of signing up.
That would explain that then - I went in there, to see what it looked like, and there wasn't much in the way of options.
- If you want to change your number after, it's choosing the exchange and then hitting the refresh button until you find something you like.
Are we to assume, that by "refresh button", you mean your browser's refresh button? I was under the impression, from what was said earlier, that there'd be a refresh button within the "Change your number" section, but I didn't see one, or is that also only available at the time of signing up? 🤔
Sorry, I was working from memory, which told me that there was a possibility to relatively easy refresh the numbers of your chosen exchange... But you are correct: Right now it seems that, if you don't like the numbers represented in your chosen exchange, you have to choose another exchange, get a set of numbers for that, and then go back to the one you want a number from. Quite tedious, so new subscribers to the service are encouraged to spend plenty of time choosing their initial number, if it's the one they want to keep.
On a side note, I was surprised to see that Victoria is now out of new 250 and 778 numbers. All I got in a dozen tries was 236.
01-17-2020 11:18 PM
01-17-2020 10:41 PM
@popping wrote:Yes you can.
Since all current available PM plans has Canada wide minutes, you can pick any area code and phone without paying long distance. You can search for area code or last 4 digits.
Sale tax are charge by the area code. You can get a AB area code just to pay 5% GST only.
- Numbers from the pool are added in the morning so if you are looking for a number with an older area code early in the day is the time to find one. Keep in mind that recycled numbers could come with an unpleasant history
- only one number change per 30 days
01-17-2020 09:48 PM
@AE_Collector wrote:
@marimacas wrote:Are you an active on PM or going to obtain a new number?
Those could both be true. I think you meant "Are you an existing PM customer or Creating a New Account"?
AE_Collector
Yes, that what I meant.
01-17-2020 09:11 PM - edited 01-17-2020 11:01 PM
Those could both be true. I think you meant "Are you an existing PM customer or are you Creating a New Account"?
AE_Collector
01-17-2020 09:07 PM
@xlarin One other thing to keep in mind..... although I ported my existing number from another provider, and haven't seen & used the option to choose a number, I expect that like most of these kind of things, there's PROBABLY a limit to the number of times you can refresh the list of numbers to pick from, and your choice may be somewhat limited..... I suppose one of the other, wiser, PM grizzled veterans can shed some light on that particular topic.
01-17-2020 08:55 PM
@xlarin wrote:Hello! Can I choose a "public mobile" phone number that I like? How and where to do it?
https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
Choose your Phone Number
You can transfer your number from another provider or select a new number. In either case, here’s what you should know:
01-17-2020 08:53 PM
Yes you can.
01-17-2020 08:42 PM - edited 01-17-2020 08:46 PM
If your're already a customer, logon your self-serve account.
Change Your Phone Number
To change your phone number: sign in to Self-Serve, select ‘Change Number' under 'My Profile' on the Overview page. Here, you can choose to select a new phone number or to transfer a wireless or wireline number from another provider.
After choosing your city (which determines the area code), you'll be presented with a list of numbers to choose from. If you don't see anything you like, you can continue refreshing the list until you find a suitable number.
More info here: https://www.publicmobile.ca/en/on/get-help/articles/choose-your-phone-number
