auto pay
brent1953
i just switched my credit card to my new one n it says auto pay is active but its not showing up on my account  in my rewards... is it cause i just changed things over. n it will show up later?
brent1953
yes its showing now, thanks
@RossN wrote:
@brent1953 hi your autopay will show up when your next payment is deducted
It's true that the $2 autopay discount gets applied at renewal time, but when enabling autopay, the $2 should be shown in the rewards section immediately.
If you removed the previous credit card and added a new one, did you enable the autopay option? Simply adding a card does not do that.
RossN
@brent1953 hi your autopay reward will show up when your next payment is deducted
