10-25-2017 08:22 PM - edited 01-05-2022 03:27 AM
How find out who called while my phone had no reception.
It happens often that I lose reception and I miss calls. But I only learn about it after caller tells me.
Service
10-26-2017 03:55 PM - edited 10-26-2017 03:57 PM
@minay wrote:i have an iphone so do i set call forwading through it or from PM
Although the actual forwarding is done on PM's side of things you would set it up from your iPhone itself as I don't believe PM's self-serve site lets you do so.
This means at the time you are setting up the forwarding you need to have a signal and be in the coverage area for PM so your phone can tell PM what to do. 🙂
Call forwarding, call waiting, and other call features on iPhone
(Follow the instructions for GSM in the above link, not CDMA)
10-26-2017 01:28 PM
10-26-2017 01:27 PM
thank you all for the replies
10-26-2017 01:21 PM
10-26-2017 11:49 AM
@koimr1 sounds like a good workaround!
10-26-2017 10:50 AM - edited 10-26-2017 10:51 AM
@minay wrote:How find out who called while my phone had no reception.
I have my phone set to forward busy/unanswered/unreachable incoming calls to my Fongo number and that seems to work well enough for me.
If you at least have wifi the Fongo app will ring and if you don't the call logs on the Fongo website will show any missed calls.
10-25-2017 10:55 PM
10-25-2017 10:25 PM
yes, like what other people have said, there is no way you can find out who called unless they left a voicemail. hopefully pm fizes that problem by sending a text msg for those who called while u had no service.
10-25-2017 09:35 PM
I have to say, the missed calls text is the only thing I miss about Wind. But I guess I don't miss many calls anymore because I have reception more often.
Would be nice if they added this feature in the future though.
10-25-2017 09:23 PM
10-25-2017 08:33 PM
I agree with @will13am.
PM does not offer the equivalent of Fido and Wind/Freedom's who called service.
10-25-2017 08:25 PM
If your phone is disconnected from the network, calls should go directly to voice mail. From there you have to rely on the caller to leave a message. Otherwise, not sure how the calls can be logged by the user.
