Wednesday
Wednesday
I just gave you a bravo. It seems that I can give bravos by my phone but not from my MacBook . I assume the problem is my MacBook .
Wednesday
Interesting is there a limit on how many bravos you can give or take?
Wednesday
Wednesday
Wednesday
Sorry I just tried to give you the solution but it seems my post has been moved to the lounge - what ever that is.
Wednesday
It seems that you haven't read anything I posted --- please forget about this post .
Wednesday
hi @Anerkons
so, is giving bravos broken? i still see only 11, did you try giving some bravos to test it out?
Wednesday
I know better than to try to bravo my posts. And yes thanks for correcting me - the total bravos I gave so far is 11 and bravos received just went up to 14. As I suspect this must be a glitch most likely on my side that I am not too concerned about.
Wednesday
@Anerkons wrote:Noticed that you have given 2,867 Bravos compared to my insignificant 13 Bravos. Just tried to give you Bravo but it was greyed out so I'm assuming that there must be a glitch that's causing this.
hi @Anerkons
the 13 , or now 14, bravos you referred are the bravos you received, not gave to other. it will only increase when other gives you the bravos
so, you probably talking about unable to give bravos to yourself, which is blocked as it will be considered as gaming
Wednesday
@Anerkons Normally only your own posts are greyed out so there are no self bravos. Is this on your phone, desktop, browser, app?
Wednesday
Wednesday
