10-05-2018 09:02 AM - edited 01-05-2022 02:02 AM
Hello, I currently have limited talk and text plan (i.e. 50 minutes & 50 out-going texts) but have purchased a US roaming package for unlimited talk and text - am I still confined to the 50 minutes & 50 outgoing texts or while I am roaming is this truly unlimited?
Thanks!
10-05-2018 09:11 AM
@bblackman, you should not be. The US roaming add-on is for use while in the US whereas the plan features are for use while in Canada.
10-05-2018 09:10 AM
US roaming and your current plan are separated.
So you will have unlimited calling while you in USA, if you inside canada, you will use your current plan.
