09-07-2016 02:05 PM - edited 01-04-2022 03:12 PM
If i sign up for a month of service with Public Mobile, is there a period of time when I can withdraw and get a refund if there is no usable signal at my home?
I have a very weak Rogers signal at the moment and I'm hoping for something better than this.
09-07-2016 03:58 PM
Very good advice @kav2001c, definitely a better test with voice or data than text.
09-07-2016 03:50 PM
I would suggest testing a 10 day data plan not a 10 day txt plan
TXT is by far the most forgiving if you live in a fringe coverage area
Voice & data you will see alot more problems with if you wish to test the network
$15 for data (compared to $11 for txt)
09-07-2016 02:17 PM
Here is the post about $11 Risk Free activation: http://productioncommunity.publicmobile.ca/t5/Getting-Started/Risk-Free-Activation-costs-11/m-p/2877...
09-07-2016 02:13 PM - edited 09-07-2016 02:15 PM
There will be no refunds as it is a pre-paid service but the easy way to see is check the Telus coverage map... If you are in it you are covered. PM uses Telus towers.
If worried still, try a 10 day service plan ... if not happy just do not pay for the renewal, if happy upgrade to 90 day (best savings)
or look here: https://publicmobile.ca/en/on/coverage
