Took wrong data rewards
dinaryl
Can my data be changed to Canadian data instead of US data?
2 REPLIES 2
JL9
Are you living in Canada and arent travelling to the US? CS Agent should be able to help transfer the value over to add on you wanted.
Roaming services can't be used while you're in Canada.  Officially, there's a no refund policy at Public Mobile.  To see if you're eligble for a credit as a exception, pelase open a ticket to a customer support agent by going to:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
