03-14-2019 01:32 AM - edited 01-05-2022 03:41 AM
I have browsed through a number of posts regarding SMS. I think my issue has started since I used the US roaming add-on a couple months ago. SMS is not working consistently. Sometimes, messages don't get sent out or it takes over 10 minutes to receive a message. I tried setting the SMSC number to 16475800172 using *#*#4636#*#*. I keep getting the "update error" message. Rebooted and shut down a number of times but still no luck.
Any suggestions will be greatly appreciated. Thank you!
03-14-2019 03:15 AM
@RobertQc Putting the sim in another phone is almost the last thing I can try. I've also tried different messaging apps to rule out a possible app issue.
Thank you so much for the link to message the moderator. I was just about to post a question to ask for it and got your message.
03-14-2019 03:09 AM - edited 03-14-2019 03:10 AM
@gtidriver wrote:@popping I tried the steps you suggested. Unfortunately, the symptoms persist.
@gtidriver I assume with all of your testing you have tried your sim in another phone to be able to rule out any local issues?
I also suggest sending a message to the moderator team to see if they might be able to reset your sms account on their end. Click this to send them a message.
03-14-2019 03:05 AM
03-14-2019 01:54 AM
@gtidriver wrote:I have browsed through a number of posts regarding SMS. I think my issue has started since I used the US roaming add-on a couple months ago. SMS is not working consistently. Sometimes, messages don't get sent out or it takes over 10 minutes to receive a message. I tried setting the SMSC number to 16475800172 using *#*#4636#*#*. I keep getting the "update error" message. Rebooted and shut down a number of times but still no luck.
Try the lost/stolen phone trick to re-provision your plan features again.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is about 48 hours. Good luck.
