Referral a friend
mimi530
Can I add my friend’s referral code after I activated??
kb_mv
@mimi530 You most certainly can. Contact the moderators and explain it to them.
You can contact the mods one of 2 ways. Click the question mark bottom right of the browser as shown in the picture and open a ticket through the automated ticketing system;
or you can contact them through direct messaging at the following link (note this way may take longer for a response);
In either case you should receive a reply within 48 hours though typically they are much faster. Watch the envelope icon top right for a reply.
iliketotalk
try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue , you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
Staliger
@mimi530 Yes, contact mods for that. Click on ? on bottom right of the page and follow directions to create a ticket.
