Referral Rewards
JL9
Hey Gang,
What happens if someone referred put the wrong area code in and therefore the number didn't reject the referral?
What is the best way for this to be rectified?
Thanks
13 REPLIES 13
maggielinca
Thank you. I just sent you a private message for the info. Hope the transfer can be success...
CS_Agent
Customer Support Agent
@maggielinca, I'd definitely assist you with this matter. I just sent you a private message. Please provide me with the requested information so that we can sort the issue out.
Thank you 🙂
Aïssata
maggielinca
Thanks. I will wait...
Hi @maggielinca, If your port is stuck, and you have already sent a private message to the moderator team, there is not much to do but wait.  They handle requests on a first come first served basis.  Wait time depends on how many others have sent in requests.
In the mean time, you should be able to use your old SIM (7-11).  when it dies, you know your port has been completed.
maggielinca
Do you know how long it will take to resolve the phone number porting issue from 7-11 Speakout? I sent a PM to @Moderator_Team with the account information and the details.  But I haven't heard anything from them for a while.
Thanks
Maggie
GreatCanadian
I wasn't even aware that you could select your own post as a solution! Watch my rewards go up now!!!  🙂 Joking of course!!
GC
shartomjam
@JL9 wrote:
Oh sorry, that was inadvertent. I meant to accept your last response as the solution. Can this be done still?
Yes, it can.  See this link: https://productioncommunity.publicmobile.ca/t5/Public-Lab/Allowing-you-to-change-the-quot-solution-q... .  Thanks, I learned something too!
dna2016
As @shartomjam mentioned it cannot be reversed, you need to be exact when entering the referral number.  Looks like your friend will need to give you $12 a year for as long as they are with PM.
And @JL9 please be sure to only accept solutions that were made by others.  I assume you did this in error.  This is put in place to help out the PM community, since there is no actual customer service phone line, these solutions are helpful for those who may not need to contact a moderator.
shartomjam
@JL9  FYI - You accepted your own comment as the solution instead of accepting the answer to your question as the solution.
JL9
Oh ok. Thanks for the heads up guys. Guess he will have to buy me a 12 pack lol
mimmo
Its my understanding is referrals can not be added after the fact even if 1 digit was wrong.
shartomjam
I am not sure this can be rectified but you can try sending a PM to @CS_Agent with the account information and the details.  There are many other posts where the referral was not entered and the mods are not able to add it after activation.
