Re: Over charged
RVsingh
me same can you tell how u fix that problem
1 REPLY 1
slusagm
@RVsingh overcharged? Over by how much?
Use browser with incognito mode to go to Payment History page on My Account and check if they really overcharged you. If they didz open a ticket with PM.
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
