Question
Dio331
 Hello,
I just ported my old phone number from TELUS to Public Mobile and everything is working great.
I had no contract with Telus and my question is: do I have to contact TELUS now to tell them I switched providers?
Thank you very much for you help.
trshtup
I just went through the same process with Bell, and was concerned about my servive being canceled as well.  A couple of days after dialing every thing in with PM I called Bell to make sure everything was legit, and it was.  I imagine Telus is the same - your service with them will be deactivated but you should definalety call them to get confirmation on the cost of your final bill (or credit if you're lucky).  🙂
ayoung3366
once your port your number from Telus it automatically cancels your plan with them so there is no need to contact Telus after.
jheili99
hi and welcome..
now, once port was successful Telus account will automatically close...and they will send you a final bill ..
cheers
