11-30-2016 07:32 AM - edited 01-05-2022 01:04 AM
11-30-2016 02:01 PM
Yes, definitely request your service renewal date be reset to 90 days... you paid for that time, they need to honour it. Hope it's sooner than later! ![]()
11-30-2016 01:51 PM
I did send a private message to a moderator, but I don't think it will make much of a difference.
It seems that Public Mobile greatly underestimated the number of people who would switch over and the problems that would come with it.
I removed my Public Mobile SIM from my phone, as the service is unusable right now with no incoming communications. Back to my old provider till support can get things working, which does not seem like it will be anytime soon.
I expect to be credited for the PM service while it does not work...
11-30-2016 08:43 AM
@Ianrenauld definitely frustrating! You can try tagging one of the moderators... but I don't know if they'll respond. They start work at 9:00 am EST. Best bet would be to send a private message first and then follow up with tagging.
If you check out the Users Online page, moderators have this tag beside their names. Hover over their name and you'll see a pop-up with Send Message in orange. It doesn't matter which moderator you send a message to, because your message will go into a pool that each moderator can see. Include your phone number or account number in that message.
