02-01-2018 12:02 PM - edited 01-04-2022 03:26 PM
Are you able to customize your last four digits after u got the phone number
02-01-2018 12:48 PM
I don't think you can customize exactly the last four digits of your phone number, but when you log into your own self serve account, click on "Plans and Add-On" tab, and then click "Change Phone Number" you can select a new number from a pre-selected list of available numbers depending on which local calling area you want.
02-01-2018 12:45 PM
The number selection process offer beer little choice. There's no option for customization. You get a tiny pick list.
02-01-2018 12:44 PM
You can only do that during an activation of your first SIM. If you want to attempt to customize your number after you have an account, the only way to do that is to buy a new SIM, and reactivate it as if you're a brand new customer, as you would need a brand new account.
