05-21-2019 05:39 PM - edited 01-05-2022 05:01 AM
Hi, I frequently use my phone for long hours talking to my fiance. I always get disconnected before 2 hours and then more frequently afterward. Generally, this doesn't bother us but I now need to make long business calls and I got disconnected today. This can't happen with work. How can I stop this from happening?
Thanks
Shawn
09-12-2019 01:06 PM
@PlanShopper wrote:
Welcome to Public Mobile where Less for less means they give you trash service and pretend nothing is wrong until the news gets ahold of it and they have to do something about it. Dropped calls, pffft, this is Public Mobile it's the only thing they can do consistently!
Who cares as long as you're saving $3, right?
It depends where u are when making the call and what may be interfering. Also depends where your contact is and who their wireless service provider is. The issue isn’t always with public mobile.
05-23-2019 07:10 PM
05-21-2019 05:53 PM
No, this is my only phone. Haven't tried those. The phone worked fine on Koodo so i figured it should okay with PM.
05-21-2019 05:44 PM
@shawnmackay1593 Calls disconnecting just after 2 hours is common on PM. But that is the limit set on network side. However, this should not affect call drops afterwards. Have you tried using any other unlocked phone or resetting network settings or factory reset?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
