Oneplus 3/T, 4.0.2 just released ...
01-17-2017 08:36 PM - edited 01-04-2022 01:26 PM
If you were one of the people affected by the 4.x release at the end of year end and had to recreate your PM APN, they released 4.0.1 to fix that. Today I noticed they have released 4.0.2. Just a heads up if you are a Oneplus 3/T owner. Be sure to double check your APN after upgrading.
Official 4.0.2 thread 4.0.2 release notes
Phones
01-25-2017 02:18 PM - edited 01-25-2017 02:20 PM
Nothing more to add that others haven't already answered. PM's APN settings were readded in 4.0.1, so if you have either 4.0.1 or 4.0.2, you are all set for PM.
The APN settings themselves can be found on various links but this one hosts one of the largest collections for various makes/models and carriers - https://apn-canada.gishan.net/net_15_public_mobile_internet_and_mms_settings.php
I believe you will find the PM community second to none, so hope you make the transition from Fido soon 🙂
01-25-2017 12:18 AM
Yep, Latest version here.
Thanks guys.
01-25-2017 12:09 AM - edited 01-25-2017 12:09 AM
Regarding APN, you probably won't need to enter it manually, it should set automatically as long as you are not on OxygenOS 4.0.0. If you are then I recommend you update to 4.0.1 or 4.0.2 first as they resolve the APN issue that plagued 4.0.0.
01-24-2017 11:08 PM
Honestly, I love OnePlus 3 with Public Mobile. It works flawlessly, and you may not even have to get the APN yourself all times, sometimes it's already there.
The APN settings are
01-24-2017 11:03 PM
How is OnePlus 3 with Public Mobile?
Also, where can i find APN settings for Public Mobile?
(I am thinking of switching from Fido)
Thanks
01-18-2017 01:18 AM
For me, the original update to Nougat erased by APN settings, and once I re-applied them I had data again, but thanks for the heads up!
01-17-2017 10:06 PM
I see that they are at least a lot more proactive then freaking Samsung, or even Google for updates
01-17-2017 09:19 PM
@Vickel yep, myself included 🙂 (OP3)
01-17-2017 08:45 PM
Thanks for the heads up. I think there are a bunch of users with the phone.
01-17-2017 08:42 PM
Guess I should add that I found no APN changes, everything worked as intended, your mileage may vary 🙂
