No servive
Options
09-20-2022 08:24 PM
Anyone else having service issues currently in nova scotia
2 REPLIES 2
Options
09-21-2022 07:03 AM
What kind of issues @Bourgeois7 ... did you try restarting your phone?
There may be different troubleshooting shooting to try depending on your symptoms or issues you are experiencing?
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Options
09-20-2022 09:18 PM
Might you have done a plan change very recently?
