08-11-2016 10:32 PM - edited 01-04-2022 03:00 PM
08-12-2016 01:15 PM
Welcome to Public Mobile, @spitnut! Please give us a brief update to let us know that all is well after rebooting. Thanks @Mary_M! 🙂
08-12-2016 10:34 AM
Good morning @spitnut
Sorry to hear about this.
Everything has been resolved - please power cycle your phone and test your services. You should be able to make calls, send texts and use your data.
Also, you do not have a self-serve account, therefor you will need to create one. Please visit https://selfserve.publicmobile.ca/self-registration/ and follow the steps.
I hope this helps!
Mary
08-11-2016 11:53 PM
08-11-2016 10:44 PM
08-11-2016 10:35 PM
1) Does your phone say you are on the Public Mobile network? You might need to fiddle around with the APN settings to get data.
2) You might need to port your number over
3) You need to get a new number from PM if you didn't port
