Missing credit
MerryK
I do not see $1 off from my bill for "referring a friend" and this friend is still a customer of Public Mobile.  Who can I ask to get the reward onto the bill?  Thanks
dude65
You should be able to see in your selfserve account the last 4 phone# of all your referals. If you are missing any by mistake, contact a moderator. If the referal has left PM, you will not get at loyality  for that 1.
@MerryK contact customer support here
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
@MerryK wrote:
Do not see digit info under Rewards nor "Refer a friend" in payment history.
Then somehow your account got affected by a recent-ish bug fix to do with refer a friend rewards. You'll need to contact the moderators to let them know that your friend is still a customer. As long as they haven't gone into suspension of course.
MerryK
Click on My Rewards button and then the little arrow next to Total rewards earned on the left side to expand the rewards. Do you see the last 4 digits of your "friend"?
In your payment history do you see any line about refer a friend?
