Locked Phone
Leapfrog
I have a phone that is locked I put in the iMei no. And it said it will work on the network. Do I have to get the phone unlocked?
8 REPLIES 8
chukdefatey
^Appreciate it
@chukdefatey,
Thanks for the explanation. You are forgiven 🙂
chukdefatey
^which is why I said as far as I recall. Which means I wasn't 100% sure
@chukdefatey,
I suggest you to download the manual of the Samsung Corby Pro GT-B5310R from Samsung here.
Maximum measured SAR values for the B5310R are :
GSM 850
Head: 0.50 W/kg
Body: 1.04 W/kg
GSM 1900
Head: 0.48 W/kg
Body: 0.55 W/kg
UMTS Band 5
Head: 0.38 W/kg
Body: 0.40 W/kg
UMTS Band 2
Head: 0.95 W/kg
Body: 0.54 W/kg
and
http://www.phonearena.com/phones/Samsung-Corby-Pro-B5310R_id4545
This phone is compatible with Telus/Koodo/Public Mobile 3G network once unlocked.
chukdefatey
@Leapfrog, IMEI cheker is a very very basic tool & it shouldn't be relied on. As far as I recall that corby pro is a 2G GSM only phone which means it will not run on PM's HSPA+ network. So your only options is Rogers, Fido & Chatr
@Leapfrog,
You have to purchase an IMEI unlock code to be able to unlock it and use it on Public Mobile.
You can buy this code on eBay or I recommended this place : www.cellunlocker.net
If you have the original box, please verify that your phone support :
3G UMTS/HSPA (850MHz/1900MHz)
Leapfrog
My phone is a Samsung Corby Pro from Rogers
Cyber
@Leapfrog,
What is the make and model of your phone and where it was purchased ?
If your phone is locked to Telus or Koodo, no unlock needed to use it on Public Mobile.
