Iphone users
mfizz55
My question is can Iphone users go with Public Mobile?
@Anonymous wrote:
Yes you can used any iphone if is unlock
Good Luck
The original iPhone model will not work on Public Mobile even after unlocking it.
Poogzley
Just a warning some older iPhone like the 5, 4S, 4, 3GS and so on sometimes encounter issues with Public Mobiles APN settings. That being said this can usually be resolved with a little perciverance and tinkering.
Alex888
@mfizz55 Yes, but check your specific model on http://willmyphonework.net/ before you register.
Good Luck
