How do I use the plan builder?
Val_T
Retraité / Retired
Retraité / Retired
Choosing your plan is easy. All you need to do is to make a selection in each of the four columns; Days; Unlimited Talk; Unlimited Text; and Data. If you don’t need services in one of the columns, click “None”. Once you have picked the options you want, the plan builder tool will generate a plan code and a discount, if applicable.
Don’t see a plan code?
If the plan builder didn’t generate a plan code, it’s probably because a selection was missed in one of the four columns. For example, if all you need is Province-wide Talk and Unlimited Canada-Wide Text, select “None” for Data. Add-ons can be purchased at any time through your Self Serve account, either during the activation process or a later date.
1 REPLY 1
makkahn28
I will admit: The build a plan interface is not too bad, but prices is horrible, rewards may not be enough to off set certain aspects. Rewards alone aren't enough for ppl to make the switch 110% The way New PM is doing things, This may polarise everything.
