05-04-2017 07:37 PM - edited 01-05-2022 02:02 AM
I wanted to request a moderator to help me renew my 90-day plan as I have run out of data and I do not wish to purchase the add-on since I am technically near the end of my plan for the duration of the 90 days.
Someone help? I already have the funds available, just need a technical processing.
Thanks.
05-04-2017 07:46 PM - edited 05-04-2017 07:47 PM
Hi @noodlez7,
As you said, you'll need the assistance of a moderator to check this for you.
I suggest you send them a private message. Be sure to include your phone number as well as a description of your problem. Click here to know how contact them. They are available from Mon-Thursday 9am to 9pm and Friday-Sunday from 9am to 5:30pm (eastern time).
I hope your problem will be solved quickly :
