Data sharing
02-04-2019 03:21 PM - edited 01-05-2022 03:15 AM
Hi
I am wondering if it is possible to share the data i currently have on my package with another SIM card that I would like to use in my turbo hub. Or do I need a complete different package to have the data for the turbo hub. Thanks.
Joining Public
02-04-2019 05:20 PM
Yeah the data plans are not too bad. Was just seeing if this was an option as I don't use much of the data that I have on my package now. Thanks again
02-04-2019 05:17 PM
@Gordonpower279 wrote:Hi
Tethering won't work as the turbo hub will be in a remote location so I can access a camera system I have installed there. Thanks for the response.
@Gordonpower279 ah, then yes unfortunately you would require a separate SIM card and account for that. To be honest, Public Mobile is not terribly cost-effective for a data-only plan.
02-04-2019 04:40 PM
Hi
02-04-2019 04:30 PM
Hi Gordon,
i wanted to do something similar, however no sharing of data on PM. You could tether though if that helps.
Cheers,
mj23
02-04-2019 03:32 PM
Hi @Gordonpower279, as mentioned, tethering is the only way to share the data, as it's only one SIM per account.
02-04-2019 03:27 PM
Hi,
I have never attempted to use a PM sim in a hub but i know there is no way to share the data except for using hotspot from your phone.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
