11-18-2016 06:24 PM - edited 01-05-2022 12:37 AM
Hi,
I was wondering if the remaining balance of an add-on purchased is carried forward indefinitely or just for one month.
11-18-2016 07:34 PM
Hey @jimmyche, I think you should remove your footer asking people for bravos and marked solutions. Either people give you them or not. Just be active daily and the rewards will come.
11-18-2016 06:30 PM
Any non roaming related add on will have the remaining amount carried forward indefinitely.
Long distance add on is NOT roaming related.
If this post helps you, please bravo.
If this post solves your question, please mark as solution.
11-18-2016 06:26 PM - edited 11-18-2016 06:32 PM
If you purchased say 200 minutes North American calling they stay with you until they are all used. They do not expire at the end of the current term you are on.
if it is the US Add-on it is a 10 day term from when you purchase it
