03-05-2018 11:42 AM - edited 01-04-2022 03:39 PM
Hello,
I hope everyone is well.
I am attempting to activate my SIM card which I bought from Walmart yesturday.
However, the activation site does not accept my 18 digit number which is at the back of my SIM card because it: 'Doesn't belong to a valid public mobile subscriber.' I have been careful entering in my number, which is correct.
However, when I try to create an account it asks me for a valid mobile number. Unfortunatly, it isn't acepting my phone number. Thus, I can't create an acccount or register my sim.
Did anyone have a similar problem. If so, how did you fix it?
Kind regards
Jamie Lawson
Joining Public
03-05-2018 12:33 PM
This did it,
THANK YOU SO MUCH!
03-05-2018 12:28 PM
@Anonymous, you need to read the OP's post they HAVE a SIM and are just trying to activate it and your post is telling them how to get a SIM?!?!?!
03-05-2018 12:20 PM - edited 03-05-2018 12:37 PM
you can by Public Mobile Online Activation
@ https://activate.publicmobile.ca
good luck
03-05-2018 12:07 PM
This problem is very likely due to self serve portal problems. Try clearing browser cache, using incognito mode or different browser. These workarounds are often very effective.
03-05-2018 12:04 PM - edited 03-05-2018 12:05 PM
Hi Civic_E
Thank you for the reply.
Do you know how I can access the Freedom mobile's number pool without activiating my sim or having an existing account?
The reason being is I don't have a valid cell phone number as I have recently become a Perminant Resident and I have a UK number I cannot port.
The problem is I can't register my sim without being a 'public mobile subscriber' and I can't start an account without having a cell phone number.
Many thanks,
Jamie_law
03-05-2018 11:54 AM - edited 03-05-2018 11:55 AM
Are you trying to port your number or you are getting a new number?
If you are porting a number it must be a Canadian number from one of the existing provider. I don't think you can port VoIP numbers such as TextNow or fongo numbers.
Other option is to choose a number from Public Mobile's number pool. You can also chose last 4 digits! I would suggest you chose a new number then port to keep things simple
