Account set up
suner
why does it take a few hours for the new account to activate?
@suner wrote:
it has activated now, but i have no internet
You'll probaby need to configure APN settings. Here's a good starting point:  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-And...
Jb456
Check your APN settings on your phone
It should be this.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
suner
cavemantoronto
It doesn't. Activation is immediate if it worked. What hapenned?
kselmak
Account should be active instantly
There may be something wrong with the website it has been acting up
iliketotalk
@suner hi I assume you mean you are porting a number from another provider? if so that is normal you can use old sim until your port is complete when it stops working you should be good landlines and voip can be much longer where are you porting from?
