02-21-2018 04:39 PM - edited 01-05-2022 04:13 AM
Good afternoon,
Can any Mod help me unlock my account? I can't use the "forgot your password" option. It says that my account is locked.
Thank you
09-30-2018 07:29 PM
@Mathewpp wrote:Hi please Any Moderator could help me reactivating my account that has been locked? Please I need to access self serve to add/change my plan
thank you
Have you tried the password reset function to get you into your account?
09-30-2018 07:13 PM
thank you
05-29-2018 01:47 PM - last edited on 05-29-2018 02:23 PM by CS_Agent
Hi There
I am Neelam bhardwaj, my email id is [email protected] and phone number is xxx-xxx-xxxx.
I am tried to access my account but its showing locked. Can you please activate my account
thanks
Neelam
03-01-2018 11:14 AM
Thank you. I only noticed that after I had sent you a message. I appreciate the reply.
03-01-2018 11:09 AM
@MG10wrote:I Can't sign in or change my password. I think my pay period has expired. How do I get access again?
@MG10, you should actually create a separate thread when posting your issue. It will receive much greater visibility. That said, password changes are not affected by account expiry. The reset function is a bit buggy. I suggest contacting the moderator team to assist with the password reset. See above post for how to get in touch with the moderator team.
03-01-2018 11:04 AM
02-21-2018 04:48 PM
Thank you for your help. I just sent the mod a message.
02-21-2018 04:46 PM
You will need to send a private message to the Moderator_Team with your account info.
More info on contacting mods:
