02-21-2016 05:45 PM - edited 01-04-2022 12:50 PM
Hi, I just got a new unlocked nexus 5x and tried setting the apn values according to the sticky apn thread. My mobile data and picture messaging don't work. I can make and receive calls and can send normal texts. I have WiFi data.
Can anyone help?!
12-23-2016 01:00 AM
Sounds good, I'll try your approach and let you know if it works.
Thanks again.
12-23-2016 12:58 AM - edited 12-23-2016 01:00 AM
@Mana wrote:Thanks @NDesai. After the factory reset was the PM sim the first sim you inserted or did you have any other carriers sim in it right after the factory reset.
I am just trying to figure out the steps to auto populate the APN, which I think is always better than manually entering it.
After reset, PM was the first sim and before reset, it was with fido sim.
FYI, after that i have installed custom roms many times to try different roms and never ever i had to manually add apn.
12-23-2016 12:56 AM
12-23-2016 12:47 AM
@Mana If i remember correctly, I had the phone already factory reset. So, i just inserted the sim in and it connected right away.
12-22-2016 11:58 PM
@NDesai For nexus 5, did you have to factory reset the phone for it to auto populate the APN settings or just power cycle it?
02-21-2016 10:48 PM
Yup, nexus loaded settings all by it self. I had to do nothing at all.
Glad you got it working 🙂
02-21-2016 10:02 PM
Congrats, now you can fully enjoy the benefits of 3G as well as 4G LTE
02-21-2016 09:56 PM
02-21-2016 09:52 PM
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/APN-settings/m-p/30197#M4079
This is the link to edit your APN settings for your Android phone
