APN Setting Selection
Civic_E
Found this in my APN setting....
No matter what APN i select, the data works fine. Which one should i use?
Rockdaddy22
Test the speeds and use the fastest one. 🙂
Civic_E
I am aware of this post
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
and default is that one.
Just wondering if I select any other APN would it still count my usage? For example if i choose Telus APN would it count data that I have used on that APN from my allocated data?
CaNuCk07
which one defaulted?
