5s to note5
04-19-2018 11:27 PM - edited 01-05-2022 04:38 AM
Hey I switched my sim from my 5s to note5 and I can't call or text. It says service not available but sometimes it does show that I'm connected to public mobile briefly although I still can't call or text. Please help
Payment
04-20-2018 11:31 AM
@will13am, I too am a fan of stock android.
04-20-2018 08:45 AM
@GreatCanadian wrote:@will13am @ipofmc7 The Network Reset option is a very good suggestion. It will turn off mobile data, turn off VPN, forget any network settings, removes app restrictions, sets mobile network type to the best available, turns mobile data on, and a bunch of other things. Give that a shot, reboot, check your APN settings and get back to us.
GC
Yeah Samsung is a control freak which is why they have this feature. Stock android doesn't need any of this nonsense.
04-20-2018 07:20 AM
GC
04-20-2018 12:35 AM
I think for the note 5 under settings, backup and resets, there is a network reset. Not quite sure what it does, but give that a try.
04-20-2018 12:24 AM
Any advanced options?
04-20-2018 12:03 AM - edited 04-20-2018 12:04 AM
@ipofmc7 wrote:The phone works w other sims
In your network settings, make sure you are connected to Public Mobile and set the Network Settings to LTE. If the sim works in your old phone, then it's not the sim or any account related problem.
Sometimes device factory reset fixes this problem. But if you are going to try factory resetting, make sure to back up everything first.
04-19-2018 11:57 PM
04-19-2018 11:30 PM
This is definitely a phone problem. The connection should not be intermittent. That is a sign something is not right. I assume that connection is consistent when the SIM is moved back to the 5s?
