10$ plan
talnir
Hi,
Regarding the 10$ plan, the 50 minutes talk are also for incoming calls?
Thanks,
Tal
2 REPLIES 2
NDesai
FYI
Uses minutes
Doesn’t use minutes
-  Making a call
-  Answering a call
-  Retrieving voicemail messages
-  Using call forwarding
-  Calling *611 (the IVR)
-  Making or receiving calls from 911
-  Using calling apps when connected to Wifi
MacMe
Yes, the 50 minutes is for incoming calls too.
Incoming and outgoing calls both use up your 50 minutes per month.  Voicemails may also use up minutes.
Incoming texts are free though.
