3 weeks ago
Hi, I upgraded from 3G to 5G a few months ago and have been happy even though it usually shows LTE. Last couple of nights the signal went to one bar 3G then no signal, off and on, then today it has alternated between no signal, "SOS only", and a surprise - "TELUS"! I have reset my network and have one bar, no calls stay intact. Ideas?? iphone8+ and I'm in Vancouver out near UBC.
3 weeks ago - last edited 3 weeks ago
@Keenie1 lol eclipse effect or tier 3 bottom of the barrel provider . You get what you pay for . Maybe ask support to refresh your account and hope and pray it works
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
3 weeks ago
@Keenie1 - For the phone displaying TELUS - your phone may (But rarely) show TELUS as the provider name instead of Public Mobile.
PM, TELUS, and Koodo all share the same PLMN (Tower owner number network) so it probably is a 1/1,000 chance of seeing TELUS instead of Public Mobile and a 1/10,000 of seeing Koodo instead of Public Mobile.
But with bad service - please contact CS_Agent for help:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
Curiously, @Keenie1 , folks I know had the same experience between the hours of noon, and now.
I expect it was a short term blip, which may not recur.
Still, you can ask the customer support agents to reprovision your account/SIM and sometimes that does help with network issues.
