Calls go to voice mail, can not make outgoing call
damenace
Hi, I set up an account on my friend's iPhone 7S two days ago   She couldn't make outgoing call and incoming calls go straight to the voice mail.  It has a brand new number.  Airport Mode and DND are off.
9 REPLIES 9
GMac
Incoming calls were going to Voice Mail on my new phone and new account, but I removed the SIM Card and put it back. That solved the problem for me. I hope it works for you.
@softech wrote:
we have quiet some SIM provision issue this week.. whats wrong?
Quite, maybe? 😎
Meow
So she did Not port her number?
If you get no network connection or when you check mobile networks in your settings and nothing is showing up then your sim card may not have provisioned upon activation. Do you have access to your self serve account?
darlicious
@damenace
What does the voicemail message say? Anyways it sounds like the sim card did not provision correctly upon activation. Put that in the subject title when you contact customer support.
HALIMACS
You may need Agent assistance.  I presume texting works fine.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
@damenace
Did you try rebooting the phone?
Just power off the phone then power on the phone by holding down the power button on the right side then slide to power off.
@damenace   did you try to put the SIM in another phone?  Do you get the same result?
Can she even access Mobile data?
What is showing on the phone status?  SIM not provisioned? No Network? No SIM?
It sounds like there is a SIM provisioning issue.  Open a ticket with PM Support and have them to confirm. It would be an easy fix for them.
To open ticket with PM:
Now, you need to contact the Customer Support Agent to sort the situations
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
VIP_Tech
Hi @damenace
reset SIM, take out SIM, re-inserting SIM and power on,
try toggling airplane mode off/on,
try manually selecting network "3G only" or WCDMA only,
and Rebooting device..test it.
